@Xulfiqar
What is the correct torque spec for 10th Gen Civicās spindle nut/axle nut? 1.8l w/ CVT
Couldnāt find the specs for 1.8l in the service manual as there are specs only for 1.5l & 2.0l
Here in Pakistan we have the 1.5l and 1.8l (R18Z1) and AFAIK the 2.0l engine is only offered in USA & Canadian market.
⢠2.0l Civic spindle nut is of 22mm
⢠1.5l Civic spindle nut is of 24mm
And after doing a bit of research i discovered that the 1.8l and 1.5l have the same spindle size nut(part number is also same) but thereās a slight difference in part number of the driveshaft assys of both models.
Now should i use the 1.5l torque spec or the 2.0l one?
Torque specs according to fsm :
1.5l : 245 Nm/181 ft-lbs
2.0l : 181 Nm/133 ft-lbs
