Thank you! I’ve used Yokohama Advan in corolla and Blu earth in Prius, they’re best.
Yes in my personal experience BG’s aren’t that bad but definitely they’re of no comparison to Yokos or Continentals etc, also these brands comes with a price. However I’m thinking to change them with Advan’s or Michelin. Thanks for the good suggestion.
Yup I am using BG and although tempted to upgrade after driven 26k as Noise level has increased, but high prices of tyres are acting as barrier . I also have same thought that may be buying a fresh BG after every 25k may be better.
The noise isn't an issue for me really, I always have some type of music playing, its not noticeable with music on.
Then go for Michelin instead!
If concerned about fuel efficient tyres, then look for Energy saver / Energy saver + series by Michelin.
Need recommendations for best tyre size. Should i stick with original size i.e 215 55 r16 or go for 205 60r16
YES. I suggest to stick with the stock tyre size, i.e. 215/55/R16 or slightly larger, i.e. like 215/60/R16, but in no way, you should opt for 205/60/R16.
Width will be 10 mm less if opting for 205, instead of stock 215, which I won't suggest.
