Hi,I might be a fool posting this question but then there is no question foolish enough.
How do I change the clock settings of Diahatsu Mira. I have recently bought a Mira 2007 model.
Sir, I am in the same boat, I have a Mira 2006 and cannot set make the hour-min digits flash to set the time. It is so frustrating, please help if possible regards, AHS
Are you guys talking about Clock in Stereo Pre? I don't have any other clock than that in my 06 Mira.
If nothing works, remove the battery terminal at 11:59 and place it again after 20 seconds, this will set the clock at 12 o clock
u r a genious
Simple, keep it standby mode and Press .....just below Display for 5 sec. Then set H and M and then press SET. Good luck
ohh thats a real big dig to set the clock....! thanks for sharing.
I believe the method for Mira 2007 is different.
Just keep the ignition on ACC and the radio on standby. While keeping DISP button pressed continuously also press the H and M button till you reach your desired time. If you press SET button then the clock will round off to the nearest hour.
No worries friend
Keep the sound button pressing for 5 sec and keep it pushed and push H button to change Hours. It works for all Daihatsu cars
yes this works for Daihatsu ESSE also
Great thats the real method
