Clutch Plate+ pressure plate + Clutch bearing replaced
Flywheel resurfaced & polished.
Pick improved. Clutch is engaging lower. But speed is same as on high rpms before clutch & pressure plate replacement. Mechanic saying it will adjust after 50-60 km drive. Is he saying right??
Before weak clutch plate my car goes to 100+ in 3000 rpm and before replacement 80km/hr on 3000 rpm in 4th gear. After replacement doing the same with weak clutch.
