Noise is normal
Kia matlab
Dont worry Bro This knocking like sound comes when you are at low gear and speed is not enough....There is no problem in the car
Sir noise neutral per ati hai kb koi gear nai laga hota
Sounds like a clutch bearing...
yes i think so. Are clutch bearing expensive?
Not much expensive.. but labor cost will be around 5~7 thousand depending upon the mechanic..
Will it be harmful if i dont do anything
bhai new gari ha ais ka sth aisa ku kar rhay ho ap
aise hi kisi mechanic sa gari ko nahi khulwa lana abhi aik awaz arhe ha bad ma aise bht awazain aye gi
Han bhai awein kisi ko kholne nai don ga.I thought ke ksi mechanic ko dikha lon.Just for examining
Check Gear Oil if it is to the mark then your clutch bearing needs replacement and it should be done from Honda. This has got nothing to do with engine or engine oil change
this is most probably the sound from clutch bearing.few a times this noise goes away after servicing,better get it check and better go to your dealership .
your location ?
Sorry for the delayI am From Sialkot
Can someone clarify if the clutchwork / Clutch assembly is covered in Warranty claim. We took our car to Honda Avenue after it's clutch started giving up. The tech guy over there said its due to the extreme 1.5 hr daily travel routine in which the car is usually driven under gear two for 40 mins due to traffic. He said the assembly replacement would cost around 30k plus and wont be covered in the warranty.
