There is knocking like sound from the engine but When i press the clutch the it goes away and comes back right after i release the clutch.My car is just 5k driven.What could be the problem
While during driving ? Gear shifting? Under which circumstances?
When the car is on idle in neutral
claim warrenty n let honda guys chk it. . .idle rpm r high?/KK
Rpm is normal,around 1rpmClaim is problem because i had oil change from market not from Honda
Have you had one oil change till now? If it is 5k driven take it to them have the oil changed and than see if the car does the same thing. If it does than take it to Honda and have it checked under warranty. Do not mention that you had an oil change from market
But agr koi masla na hoa toh awein acha oil just 100kms k baad niklwa kr kia faeda
Bro did the problem start after the oil change or was it there before it?
By the way by doing so you will be able to maintain the warranty of your car.
Before oil change.
Than just do as I said and take the car back to them a few days later and claim it under warranty. What distance has the car covered till now?
5157 to be exact oil change when it was around 4900.Should I show it to some local mechanicAnd is it easy to get claim
First take your car to some good mechanic to get an opinion. Than take it to Honda and see what they say. If they say that there is something wrong than tell them that the car is in warranty. It won't be easy to claim as they will try to avoid doing a job and not get paid for it and try to get you to pay for it. You will have to really fight for it. They might just tell you that it is nothing and it is normal that is where your knowledge from the local mechanic will come in handy. But do not tell them that you took your car to the local mechanic
But they will say that you changed oil from local which caused problem
How will they know unless you tell them. If you have changed the oil filter as well they might recognize that. in that case take your car to some different 3s Honda dealer have the oils replaced and than take the car to your regular dealer and claim the warranty and tell them that you had he oil changed from a 3s Honda dealer
Bhai iss se toh acha hai banda hud hi problem repair krwa le.Pehle aik dealer se change krwaon phir dosre se aur phir in ke pas aon us ke bad bhi agr claim na hoa toh?
claim is easy and they will rectify problem. u have to sacrifice rs 2480 for oil change but u will retain warrenty of engine !KK
I think it is idler gear noise. This is normal. There is nothing wrong with your car. You can verify on other similar vehicles. They will also have similar sound.
I would advise you to listen to @hondacityjan17. He's giving you the best advice. Yes it's a little bit of effort required on your part.. But this is the best option you have. Your car is almost new right now, better to have the problem looked at by Honda.
bhai honda la kar harkatein waise ap ki suzuki rkhnay wali hain
True agreed
