theres a level on your gearbox, that attaches to clutch cable.
that cable goes to the clutch pedal.
keep your car in neutral
adjust your cable so that its loose, and lever is in its original position. at that original position the bearing is not rotating.
if its still rotating at that point, you have damaged/bent components.
then you can start tightening the cable to where you find your preferable driving position.
not exactly sure, but adjustments should be possible both at lever end and clutch pedal end.
