:S want to know how to adjust cng in cultus 08 EFI..at startup its like k pori cng nai mil rhi engine ko..after 2 3 throttles theak hojaty hai..any solution?AND my cultus giving almost 130 without any and round 100 with partial ac..its fine or bad??any solution ??thanx in advance:) Click here for SOLUTION
views 17 and no reply:(
Go to suzuki 3s dealership and tell them ur problem.
Sent from my GT-I9100 using PW Forums mobile app
I think u r getting very low mileage on cngMy czn cultux 2007 gives 180+ average with full ac
Sent from my LT26i using PW Forums mobile app
There is a small knob on CNG kit from where you can increase or decrease the flow of gas.Mileage per cylinder depends upon how much gas is filled in it. Next time, when you get a refill, note down the amount of gas pumped into the cylinder. Then make any decision.
my recent filling was 7.75kg and i got 135 kms in this gas...is it normal??
cultus efi starts on petrol,after 90 seconds,accelerate upto 2000 rpm and it will automatically convert to cng,and cng is lambda controlled(if ff cng),the gas cannot be adjusted,
mene switch extra bhi lgwaya hai jo within 2 sec change krdaita fuel on gasand cng is ff...
it means that the LC01 is disconnected,so no lambda-go to any cng wala and ask for the adjustment.
Yes. The mileage is fine (17.41 km/kg). Depends a lot upon driving condition.
Cultus owners usually get that stepper motor lambda and stock switch removed and install a manual T, gas valve with custom switch. So, I told him to do the settings from the kit.
