My car is baleno 2005 cng use nhe krta cylinder removed hai lekin kit installed hai with original separate advancer and emulator Jo company ne lgaye thy ab advancer me kuch msla hogya hai jis ki wjah se car long self leti hai aur zyada msla ho to start he nhe hoti jitna bhi self lga lo, mein wiring k sath koi changing nhe krna chahta to Kya aftermarket advancer emulator inhi dono grips k sath lag skta hai like tomasetto company ka jo kafi common hai market mein ya something better than that?
@Xulfiqar
Your writing style shows you are self-good-enough to tackle situations like this without taking advice from others.
There is an extra additional bypass grip provided with factory fitted advancer in case of faulty advancer detached existing wire grip from advancer and attached bypass grip to the advancer your problem will be solved and there will be no issue running on petrol.
I only see 2 grips one attached to advancer and one attached to emulator, where is extra grip and how is it going to solve the problem when problem is in the advancer itself?
I know basics but advice is always important
i believe the original advancer/emulator is made by LandiRenzo, which might not be compatible with tomaseto.
try finding the used emulator advancer from the CNG shops, and give them a try.
no guarantee of used part either it will run 3 days or 3 years but yeah if I'm not able to find a new one which is compatible with current setup then I will have to compromise with used
can't find extra grip please guide with which wire is it attached?
You're advancer would have an extra port or there would be another plug with grip not connected to anything. You will need to disconnect grip from advancer and connect to other port/grip and it will bypass advancer.
BTW its petrol timing retarder, not advancer
I checked but couldn't find the other spare grip
Then there should be a bypass port on advancer. Usually it's hidden under some sort of cover
Ok I will check tomorrow morning, if there's another port in advancer then I should connect the same connector in that port and it will bypass it, right?
Yes, it should have it written as well
