@chm
Look what research says about CNG:
"The life of an engine increases by using CNG. Lubricating oil life is extended considerably because CNG does not contaminate and dilute the crankcase oil. Due to the absence of any lead content lead fouling of plugs is completely eliminated and plug life is greatly extended. Another aspect, which increases engine life, is that CNG enters the engine in the form of a gas whereas petrol or diesel enters in the form of spray or mist. This spray/mist washes down the lubricating oil from the piston ring area thereby increases the rate of depreciation of the engine. Since this is not the case when using CNG, the life of the engine increased. On the whole, the maintenance costs are reduced and engine life is increased. Some 13,000 CNG users in Pakistan would confirm that.
CNG provides easy starting, reliable idling and smooth acceleration. When your vehicle is running on CNG, you may notice its acceleration to be a bit slower which is due to a power loss of typically 5-15 per cent, which can be minimized by proper tuning on the CNG kit (e.g. advancing the spark timing) to take advantage of the high octane rating of the fuel. CNG has a Research Octane Number (RON) of 130. The power loss on CNG is generally not noticeable in ordinary city driving.CNG has a good mixture distribution quality. When the correct proportions are brought together they mix thoroughly and rapidly, which improves the combustion efficiency of the engine. The Research Octane Number of CNG is 130 as compared to 87 of premium motor gasoline. When gas fuel is used, no carbon is formed during combustion and engine stays very clean internally.
CNG has four big safety features that make it an inherently safer fuel than petrol, diesel, or LPG. Firstly, CNG has a specific gravity of 0.587. This means that it is lighter than air so if it leaks, it just rises up and dissipates into the atmosphere. On the ground other fuels will form a hazardous puddle on should a leak occur. Secondly, it has a self-ignition temperature of 700 degree centigrade as opposed to 455 degree centigrade of petrol. Thirdly, CNG has to mix air within small range of 4 to 14 percent by volume for combustion to occur. This is a far narrower range than for petrol. Fourthly, CNG cylinders are designed and built with special materials to the highest safety specifications, which make storage far safer than petrol tanks."
