Vdiagtool vc200 slight used for 22000
USB Rechargeable
This paint thickness tester is a rechargeable devices that can be charged up with a USB cable. So you don’t have to rush out and buy batteries if the device runs out of power.
Digital HD Display & LCD Backlight &180° Rotated Screen
Unlike other items, this automotive paint depth gauge has uncluttered, easy-to-read displays, that only give you the information you need at the time. Additionally, LCD backlight (Right Button) are going to be much easier to read in the dark than physical scales.
The 180° rotated screen of this paint thickness gauge allows you to read the data easily from any angles!.
Precise Fe & NFe Probe
A fast coating thickness gauge can speed up an inspection a lot! You will be able to cover the whole car much quicker than if you have to wait after each reading.
This paint gauge thickness meter adopts the precision probe which can identify magnetic metal substrate (Ferrous) and non-magnetic metal substrate (Aluminum) automatically, the coating thickness data will be measured quickly and accurately!
Single/Continuous/Difference Measurement
Single measurement (SNG): One data per measurement
Continuous measurement (CTN): Keep measuring when the probe remains on the substrate surface
Difference measurement (DIF): The difference between this measurement and the previous measurement.
Press "Down Button" to switch the units as μm, mil or mm.
BASIC/ZERO-POINT and OFFSET CALIBRATION
