hey guys
im selling off my k24a4 swap, since its a very cheap grab, im sure it'll interest many of you
the block is needing repair, its not particularly blown, the pistons, rods, crank, bearings are fine, the rotating assembly and oil pump need to be replaced which shouldnt be much of a expense or issue.
the head, gearbox, wiring, sensors, mounts, axles are perfectly brand new and hardly 2000 km driven
the specs are
-complete k24a4 (175 bhp, 160 ft/lbs torque)
-custom made race axels for 01-05 civic
-custom made mounts for 01-05 civic (can easily be modified to fit any other models, saving alot of money)
-complete wiring and sensors
-2 02 sensors and maf sensor (required, not given with swaps, cost me 37,000 aftermarket)
-5 speed manual k24 transmission
-k24a4 manual ecu
the whole swap cost me Rs.350,000/- EVERYTHING included
im willing to let it go for Rs.245,000/- with a repairable block, the swap has given no problems what so ever and has been used max 2000 km, the block blew for stupid long reasons, not any fault. The swap is bolt on to 01-05 civics without any modifications required to the body. basically a direct fit
these swaps cost less than others as the a4 is a manual engine, the other k24s are triptronic which require kpro and can cost upto 425,000 plus.
ive also got a slightly used perfect k20 type R head which ill give for Rs.50,000/-
if interested give me an email, im giving the whole swap for the price i got only the engine for... thank you
