Dear All,
Well i am having a problem lately that my car (Cultus 06 Carby) is starting to lose power in the top gear around 100 km/h esp when AC turned on. It gradually comes down to 80 and starts missing. I dont know whats the reason. Also i am not able to get it to 120 that easy now. Have to rev up a bit more in lower gears to get there. But there wasn't a problem long ago. Happens on both petrol and CNG. Though less prominent on petrol.
I have been told that it can be an exhaust valve issue. The insufficient compression becomes prominent at high engine load. For that I have been searching around ways to identify such cause and as the title says, compression and leak down tests seem to be the only way without head opening to pin point the cause.
Can anybody tell me where in Lahore can i find a compression gauge or workshop/mechanic that does this test. A wild guess would be suzuki dealerships but not sure. Also does anybody have an experience to make a custom leak down test hose??? I believe for that one doesn't necessarily require a gauge. just a 5-10 bar from regular air compressor at TDC would highlight the leaks, wouldn't it??
P.S. It doesnt consume Oil/coolant/blow bubbles in radiator/blows smoke in cam chamber etc. None of it.
Inputs/ suggestions/ comments/ welcomed.
Regards,
Nauman
EDIT1 : The actual query/ concern of the availability of the tester has been resolved. The thread is now intended to move towards resolution of the issue.
EDIT2: The issue has been resolved. Compression gauge helped to save the head and valve work. The culprit was "Retarded Ignition Timing"
