It happens to me two times on a specific location that a constant beep starts in the car for unlimited time no error light found in the metere but brakes stop working when that beep starts and next day it stops kindly tell me what is the reason?
How long does it long for, and how do you stop the car then?
when i push the brake with full power then car stops very slowly and next day when i start car again it went off
get your abs checked
Could you suggest me a better place in lahore
Have you done any brake pad replacement or brake oil top up in your car?
no i did'nt have done any brake work and brake oil is on level
Get it checked through OBD scanner, only that will be able to fully address the issue you're facing. The problem should be in your ABS but get it checked through OBD regardless.
obama car & truck centre tipu block garden town 0321 4106898 10 am to 7 pm week days only service charges apply
Hi guys i have done my car work from idrees auto. He is really a nice guy and has changed by car ABS unit. It provide me one month warrany for the unit from last 3 days its working fine. I have drived it almost 400 KM after that and ALHAMDULILAH its really working fine.
Idrees: 032204849961
