Its better and worse, both. Some advantages and some disadvantages.
im sure there are more than just one company making concrete blocks.
The disadvantage using concrete blocks is the fact that if the blocks are not made from proper mixture, or water treated/cured properly , they might crack. Where as bricks do not normally crack like that.
Apart from that, since bricks are smaller, you can make more complex shaped structures using bricks even at a smaller scale. But it might not be possible with concrete blocks cuz they are bigger..
Then there is another option as well. Why not just build your entire house out of concrete?
The problem with using bigger building blocks is that if in case it collapses, alot of it collapses together. Where as in smaller blocks, only a part of it collapses.
The advantage of using concrete blocks is that construction is faster as well.
So its entirely upto u if u want to use concrete blocks or bricks...
if u cant understand, just take a sample concrete block and a sample brick. Then try different experiments on it, like hammering etc. That shud reveal to you how much difference in physical properties is there....i think bricks are stronger.
