<table id="post2692835" class="tborder" align="center" border="0" cellpadding="6" cellspacing="0" width="100%"><tbody><tr valign="top"><td class="alt1" id="td_post_2692835" style="border-right: 1px solid rgb(199, 226, 240);"> I have tried many coolants including osaka but nasa coolant is the best,osaka is only the green water (green gola gunda)
i have good knowledge about cooling system.according to the international recommandation only use ready to use coolant and should be full your radiator with the coolant and donot mix or add water along with the coolant otherwise it dont work because water has mineral and salts and it would corrode and make rust in your radiator.
The simple test to check the coolant is:you can put nasa coolant and osaka or anyother coolant in your freezer for whole night and check in the morning .the orignal coolant should not be freezed (buruf nahi jumni chayia) this would be the best and 2 nubmer or if it freezed like water it is fake coolant.
Pls must check before using the coolant for your cooling system.fake coolant would harm your gaskit and cooling system.
</td> </tr> <tr> <td class="alt2" style="border-style: none solid solid; border-color: -moz-use-text-color rgb(199, 226, 240) rgb(199, 226, 240); border-width: 0px 1px 1px;">
</td> <td class="alt1" style="border-style: none solid solid none; border-color: -moz-use-text-color rgb(199, 226, 240) rgb(199, 226, 240) -moz-use-text-color; border-width: 0px 1px 1px 0px;" align="right">
</td></tr></tbody></table>
