Dear All,
I require help from the experts here regarding my recently bought liana. Its a 1.6 eminent variant.
Aesa hai k my car has been observed to reduce the coolant. And bottle used to get filled up instead of reducing.
After a good 300km trip in one go, i once saw a rise in heat and when checked, found that radiator water was almost zero and bottle emptied as well. Got that filled up after cooling and things were good to go again.
As per suggestions from mechanics and all other people around, have done following so far:
- Changed the radiator cap to a genuine 1.1 cap
- Radiator has been serviced. Was found to be slightly chocked.
- Changed gasket
- Changed water pump (or water body as its said)
So far its still found to be reducing coolant. Bottle level remains same, however coolant in radiator gets reduced.
Approx takes 500ml after 50km trip.
Any idea what could be the problem.?? There is no leakage as per mechanic.
