Hi,Sorry for the basic question, but I need some advice.
Could you recommend a suitable coolant for a Suzuki Cultus VXR 2019? Additionally, Could you suggest where I might find it at a reasonable price, Online ?
Thank you!
Buy 2 litres of havoline coolant and 2 litres distilled water. Simplest way to buy the best coolant.
Hi Brother, thank you for response. Regarding Havoline, is there a specific model of coolant that I should look for?
There is only a single variant sold in Pakistan, just make sure you buy from reliable source.
Look for havoline distributor nearby you. They have the coolant as well as distilled water available. This way, you will be sure the product is genuine.
Why not use Suzuki ecstar from the dealer? That's what I used in my every when I did a coolant flush at home. It was what was recommended in the owners manual.
Edit: it is more expensive than havoline.
Ensure you flush out whatevers in their completely before refilling
Because Suzuki would always recommend their own range of oils and parts.
The havoline anti-freeze is tried and tested product, so the high number of recommendations on Pakwheels. It won't overburden your pocket as well. I guess around 4500 for 2 litre of coolant.
