I suggest you to use Havoline coolant if you are want quality on a budget. It's a concentrate. 1 liter of concentrate will make 2 liters of coolant. Make sure you mix it with distilled water only.
https://www.daraz.pk/products/1-i123136233-s1280004090.html
If your cooling system is rust free, you don't need to perform an acid flush. You can flush it with distilled water only. If plain water is used by the previous owner for long time, then there would be rust in the cooling system.
You can buy distilled water very cheap if you buy directly from factory who process it. As an example I buy 6 liter bottle for the price of Rs 30 per liter from HAT Enterprises in i-9/3 industrial area Islamabad.
