Where are you measuring this loss of coolant? At the overflow reservoir? Are you measuring the contents of the reservoir without removing the radiator cap?
Check how long the car takes to meaningfully reduce the level in the overflow reservoir bottle while cold. Familiarize yourself with the residue left behind by your coolant and check around the car with a high powered flashlight.
A cooling system pressure tester can pressurize the whole system while stationary and show you small leaks, especially around aftermarket hose clamps or corroded hose barbs.
