If your mechanic is useless and no others exist to help you then go buy some tools along with floor jack and jackstands,
You will also need a soft rubber pipe to use hose water to purge the acid flush from the engine - the water hose is connected to the heater lines to push the acid flush from heater and behind thermostat.
1 or 2 small shallow tubs to inspect the debris coming out.
a source for hot water to prepare the citric acid and also use it as flushing motive.
And about 4 hours time along with some clothes you wish to throw away, some gloves and goggles to protect from burning.
