Jerk sa feel horha hy, khud slow down horahi yy race chorne pe, 10 to 20kmh pe aysa horha hy, Kia waja hoskti hy
did you or previous owner changed transmission fluid ever ?2018 model vehicle means 7 years old. if avg run is approx 50,000 km per year there is atleast 2 /3 fluid change for transmission to date
I don't know about that, I have owned this car 6 months back.I recently did maintainance from Toyota when I purchased the car. And it was ok then, but from last one day I am feeling this issue
Car mileage is 69k
sir if the 7 year old car is with low milage i'd recommend to visit a workshop with scanner. Scanner can verify the fuel trim readings. Also the in-tank fuel pump filter pouch may be clogged / or purge valve is not working so reducing fuel pressure at low rpm.
please update when problem is resolved
