Again, I am a little bit confused. So, I read again your earlier post.
If that is the case, then the fan shall start only when the temperature gauge goes above the half level.
Does this mean that the fan starts as soon as the A/C is switched on?
As I earlier suggested, please observe the complete cooling process. If you are still dissatisfied and believe that the alteration done by the electrician has disturbed factory settings then take your car to a good mechanic to restore original settings.
