I own a corolla gli 2015 , it has around 135k km on it which I clocked over last 5 years , I’m facing 2 major issues which
1. I’ve always felt that car jumps at speed 40-80 km on a Smooth road , I refreshed the front suspension With new 555 parts and Toyota Thai struts, brand new yokohama advan db552 tyres , balancing rod bushes but the issue is still there ... kia problem ho sakti hai ? Any suggestions
- During lockdown I used liqui moly catalytic converter cleaner with a drip to clean the cat con as a DIY , it backfired on me ! unfortunately the drip’s pipe got stock in the throttle body during the procedure and I’had to push it with a screw driver to get the pipe released .... check light turned on , I got the idle relearn procedure done from Toyota however I now feel my car is chocked & it hesitates to accelerate & takes too much load with rpm fluctuation on idle
