Thanks brothers for helps.i will update after wiring checking. What is i look for starter? Shorts? Any sensor in starter area?
Never mention. First starter wiring. Ecu power wires. Specially EFI main relay.Battery wires.It happens in efi cars when battery is low they don't get start due to low voltages delivers to ecu.
Ok bro.new battery placed month ago.i will check
I check Starter wiring and power wires not found anything bro. Also check ECU power wires when cranking it receive 12v No Any voltage drops.
I suspect disyributor issue
as stated before...replace distributor with good one and check...hopefully it will be resolved
Finally issue solved and engine start and run fine now. Its bad ecu. After repairing Ecu, car immidiately start. Thanks brothers for your valueble help.
I have 5afe,I buy 3distributor now but there not spark,I need it help or inbox on my WhatsApp..+243822153702
