Want to know about Corolla Axio head lights from axio owners and other experts.
When the head lights are switched on and turned to Full Mode(High Beam).The bulb/coil which works in Dim Mode(Low Beam) should switch off in Full Mode(High Beam) or it should be still in ON position simultaneously with the Full Mode(High Beam) coil?
In my case If the lever is moved slowly from Dim(Low Beam) to Full(High Beam) Mode, there comes a point where both the Full and Dim Coils/Bulbs are on Simultaneously on but when the lever reaches Full Mode, then I can see that its just the Full Mode coil/bulb that is working.Is it normal?Or should the both High and Low Beam coils work simultaneously in High Beam Mode??
