Usually the best thing to do is to stick with the stock tyre specs as mentioned on your car's driver side door's side.
That size is meant for company advertised fuel economy, helps prevent problems with the suspension and keeps the rpm / odo meter readings accurate.
For equivalent sizes that would keep things closer to stock, performance wise and still improve the car 's looks or give improved grip / cusioning, try an online equivalence chart.
