block repair is serious stuff, and need careful mending. not just remove repair & re-install. Give gentleman some time to shift in effort mode
So today I shifted from 20w50 to 10w40. Alhamdullilah no smoke and fuel economy looks like it getting better. Drive is also much better
very right choice of grade & brand., good luck
Bad news:
But no sign of water in dip stick. Some water spray from wxhaust when starting. @dani_kk
I don't know what this orange thing is but today I saw it under the driver side of the engine
power steering fluid ?? leaky wiper washer bottle ? or rusted radiator tap leak ?
Whhats that you need to slide near your car to look for leaks bro. And check your all fluids level.
You mean water throwing engine or something else?
All fluid levels are ok. Power Steering and Brake fluid
I don't think it's water throwing engine, it maybe because of a leak in the head gasket
Mechanic saying assembly of 1zz fe will cost 140k and the cams will be used of this one as japanese engine has vvti which cannot be used with this wiring and ecu
Transmission fluid.
Swap a 2zzge phir itne paisun mein lol
I will check it tomorrow but should it be red and mine is towards brown as it has never changed
Hai hydraulic fluid hi.
Has engine price increased this much? 2nz fe with wiring and ecu will cost 200k?
if you are planing for a new engine. why dont you get its own 3zzfe ? how much that cost ?
I don't think it will be available in good condition and I am till now not wanted to swap. If headgasket gets fully blown then I will get the head open and see the condition of the block and decide what to do...
Yar i guess is a steam jo rev karney me in the form of pani silencer se nikal raha hoga. smell kchange ki ap ney exhaust sey? dani bhai can tell about this better.
Maynoese in the oil cap is the biggest indicator of a blown head gasket. So now it is confirmed but the extent is not that much that it will hinder in the driving.
Seriously 200k for 2nz??People are really high on weed these days. Kisi be cheez ki Price increase Karo chahe wo local ke kyu na ho bus dollar increase price increase.One can get a good 1nz-fe in 100-120k.
