I own..gli 2010 model...oxygen sensor check light is on....do i need to change sensor..or just live with itIf change...then suggest me relevant oxygen sensor...that successfully work on it..
You need to get the oxygen sensor of your car checked by some expert mechanic because if properly serviced, there's no need to replace it and it will be almost as good as new.
The rest is your choice.I hope it helps.
take it out inspect it service it and put it again. any efi mechanic or electrician can check it
Thanks
This kills the sensor!
Happy to help.
