hola, tengo un corolla xli cvt (automatico) le coloquĂ© el control de velocidad crucero pero no me enciende luz ni tampoco conecta, querĂa preguntarte si sabes donde estĂĄ la ECU y donde debo conectar el pin conector creo diiste el pin A39 y donde conecta en la ficha espiral, gracias aguardo comentario..
Saludos
Translation:
hello, I have a corolla xli cvt (automatic) I put the cruise control but it does not turn on light nor does it connect, I wanted to ask you if you know where the ECU is and where I should connect the connector pin I think you gave the A39 pin and where it connects in the spiral tab, thank you, I await your comment ..
Greetings
