How much does it cost (approximately) to replace Galaxy S4 screen? Do i need to replace only glass or lcd, whats the cost in both cases? its glass broken, turns on, menu/back button works, rings also...but no display (only black screen).
Does the touch work?
And for those Einsteins that are gonna quote me ' Screen is black tho ';Try to see if it registers your touch- Vibrations etc.
Then you might just have to change the glass, not the lcd itself.
Around 10 to 13k will be cost of new LCD..my rough guess
Sent from my XT1033 using PW Forums mobile app
Thanks, when I touch the two buttons (menu/back) it works, but on the screen i am not sure but i think it does not work.
I checked again and the touch works, so does that mean the lcd/digitizer is ok ?(bcuz the screen is black)
Whole thing needs to be replaced. 12-13k is the cost for replacement.
My advise .. Get rid of this mobile
reason?
After replacement, I'd also advise to get rid of it, if you care about resale.
If not, then there's no problem. Keep the phone.
