Hai All,
I have purchased a 2007 model coure, I am facing a problem regarding headlights, these are very dim, I should replace these or any other solution available?
Thanks in Advance!
What is the condition of the headlights? Is the glass clear? Is the reflector in good condition? Are bulbs of good quality? Is the wiring for the bulbs intact and not spliced to make connections for DRL's e.t.c?
without doing any mod, first change the bulbs. get genuine osram, phillips or narva, h4, 55watt bulbs
In my case the cause of dim headlights was Bad ground.
Thanks everybody for suggestions, anyway I have purchased HALOGEN 100W tubes, these are the best.
Make sure to use relays too.
all bulbs are halogen.....
100 watts will put load on your stock wiring. either do a separate wire from battery to head light,
or use factory specified 55watt
any 1 tried puting any dual bulb light in coure? i want to do that please guide
