Update:-
I used my obd2 scanner to look for any live data from the cruise control system and there is nothing (attached a ss).
I dont think that it supports cruise and the car also doesn't like it when i remove the battery multiple times and mess around with the ecu as today it was running a bit funny. Its running good now but im done with this project. I removed the cruise wiring completely
If somebody wants to buy it i will sell it for a discount otherwise im returning.
Also one things that is interesting to mention. The clock spring on this corolla is incomplete from factory. The cruise control connectors on both ends of the clock spring are not connected in any way. I tested with a multimeter and it showed no continuity which means there is no wiring in the clock spring. It could be that its broken but highly unlikely in my opinion. I used the airbag connectors to make this work and worked like a charm.
Thankyou guys for the contribution
