Its not worth it .
if your car was 5-10 years old it would have been okay to mess with it but for such a new car dont mess with it.
There is no wiring present for cruise control although ECU supports it. You will have to wire from the ECU to the cruise control stalk.
You will need a cruise control stalk.
Meter doesn't have cruise control light. Maybe the light behind the meter is missing or wiring so you will have to do that too.
There is no sensor in brake pedal so you will need to replace that so when you press the brake the cruise control is cancelled automatically
