Salam everyone Is there anyone who own cultus 2006 in present or past Please reply i need to ask a question
Just ask the question
I feel vibrations inside of car even on staring at idle Idle of my car is 1000 Mechinc said paa je ini hundi a 2 Clyder is it true ??? Agr wrong ha to kasy theek hoga suggest me According to mechinc all mounts are oky Carby is also ok
Passenger side pa zyda vibration feel hoti ha as compare to driver seat
If the engine mounts are ok, I would check spark and carb cleanliness. Rough idle can also cause vibrations. But I would still suggest to check engine mounts. When you rev the engine hard is there excessive movement of engine?
First check engine mount.Than spark plug and air filter.
Engine is seems smooth when i open the Bonet there is no vibration when i touch out side of car its smooth Vibration is only on staring wheel and floor of car. I just clean the carborator from mechanic also change the air filter also recently I also change engine oil The only thing that i dont check is silencer is there any link of silencer with vibration ?
Spark plug are just replace a month agoCan u suggest me which plug are best (company)
Why car does not start when auto choke lid is closed
