your car will have an timing advancer under the glove box, it is probably acting up.
Try to bypass it, on my 2011 model, there was a extra connector ziptied to the advancer wiring. It only has one wire.
Remove the male connector from the advancer and plug it into the other (above mentioned) and then start the car to check.
Our cultus is recently having a slight idle issue but not having the right scan tool is a problem...
