Bro, first check and confirm, which oil had been in use previously?
Order of increasing viscosity of oils for gasolene engines is generally as:
0w-xx (being the thinnest and mostly for hybrids / extremely cold climates), 5w-xx (For almost all new, non-hybrid engines now a days), 10w-xx, 15w-xx and 20w-xx (being the thickest and for old engines with very high odo reading)
xx can range from 20, 30, 40 or 50, etc.
For a 2008 Cultus with Odo reading of 130k kms and above, I would personally suggest 10w-40 grade engine oil, of any reputable brand. Oil must be fully or partially synthetic, with API rating of SN / SM but not below it.
Most importantly, oil must be 100% genuine and original.
I hope it helps. Thank you.
