I m using cultus 2013 efi model and after a complete car service I m having a.c. frequent tripping problem. Just as I switched on the a.c. it starts switching on and off. I switched off the a.c. immediately and on second attempt it didn't behaved the same way but after smooth run of 2 to 3 min it started doing the same. Please help, regarding the cause of this problem. I have ruled out a.c. button problem.
check the ac related wiring in the engine bay.
check the ac relay, ac fuse, ac high pressure sensor connector, low pressure sensor connector, AC clutch connector
Ok I will get these check first and let u know thanks for the quick reply.
