Air flow is somehow ok but cooling main jaan nahi hay shaam ko cooling hoti hay din main nahi.
Who told you? Cultus with Denso AC system always came with a Serpentine condenser from factory. Very few early carby Cultuses 2000-2006 that came with Sanden AC system had Multiflow condensers.
Well my cultus came with multiflow condenser and my AC guy told me about it. Because I was insisting him to change it with multiflow one he said you already had it. Efi AC is much better than carby
Can you please post a picture of that condenser? I would like to see that Multiflow condenser that came in EFI Cultus.
If it's not multiflow then why shop guy said it's a multiflow.
Because most of these so called AC technicians don't even know the difference between both.I really don't want to argue about this though. I just wanted to have a look at what kind of Multiflow condenser your EFI Cultus has.
May be he have misguided me. Do you have Idea how to know whether it is multiflow or simple.
It would be hard for me to give any idea this way. I'm not good in that department. Google it and open the image's you will get the answer.
I did some research and found that cultus got no multiflow condensers in efi. You are right it got no multiflow condenser.
Bro my bad. Cultus got no multiflow condenser like baleno had you should go with baleno one. Hope you can forgive that mistake although humans are made to to mistakes so they can learn from them.
Now it's proved that my AC guy misguided me for that.
I told you earlier... Dont ever listen to those technicians 90% of them dont know nothing.
Ok I will try to find a good one, new for baleno also available or I have to find a kabuli one. AC compressor in my Cultus is of Denso. It means the whole system is of Denso eg condenser and other parts
Hi all. I am planning to install new AC in my 2001 Cultus carby. Any one knows a reliable, reputable place that installs new Denso AC in KARACHI? also any cost idea?
if original ac parts are in good condition , install baleno condensor and a better condensor fan. That is the only weakness of cultus
Do you know where to get spal fan in isb/rwp. Like which shop exactly and not have to search around as I don't have time for it.
You find in market like shershah in karachi and bilal gunj in lahore. New spaal fans are hell expensive also google how a spaal looks and try to find similar one. Also look for wattage too 80watt would be a good pick...
@krafiqInstead of Denso compressor, go for Sanden piston based compressor.Anyways if u need economical & good solution, u can get from CaR a/c SOLUTIONS at:0321-2590321
Yes. If ur choice is new in box.Otherwise original denso piston based compressor is the best.
Ok thank you I will follow your suggestions. Baleno condenser available as new or old. Which one is better and how about the price of both.
