I am having issue with my ac and the issue is that it keeps leaking it's refrigerant and "ustad" mechanic have a suspect in mind which is "Compressor SEAL" but i was not so sure about it so i wanna ask what should i do ? i have sanden compressor already in it.
What would be the best option from below?
First, I should just repair the compressor put the seal check condensor , evaporator and pipes for leak and call it a day
Second, I should buy new Sanden Compressor, and check if condensor or evaporator is leaked and replace it too.
Third, I should buy kabli denso compressor, new fiting, Condensor, Evaporator.
Third option is because i have heard denso work better in Cultus, Because my cultus was giving 10-11 km per liter average on AC so maybe sanden is heavy with its load too.
