@Xulfiqar pls tell me cultus efi 2010 alternator specifications watt volt ampere. Also tell me wheather alternator can run all electric accessories without battery?
If engine is running and the battery somehow fails / the battery was discharged or removed , the engine and electrical system will not die, however a jump start from another car will be required when engine is shut down.
Can we increase current or amperage of alternator without increase of voltage i.e14v?
Amps are not voltage dependent.
Then how you can increase amps with same voltage if you installed high amp aftermarket accessories than your alternator i.e audio system . What type of alternator you will use to increase amp with same fixed voltage?
You install a higher amp alternator. Make sure its compatible with your car, old cultus fuel pump control runs through the alternator.
