Dera users. I have 2006 carby cultus. The problem is when i shift from 2nd gear to third rpm goes extremely high. Same with others gears means im changing gears with high rpm. I ve changed its accelator cable but still no change. Mechanic says there is paisa in butterfly. Khairadi will remove it. Then I showed it to another mechanic he says carburetor and butterfly is fine. He use some kind of spray dont know its name. After that problem solved. My question is should i service carburetor and remove that paisa. Or that spray is ok. Dont know how long that spray will last. Some suggestions will be very appreciated. Thanks
Check the Dashpot if it's sticky it can also cause such behavior.
[/quote]
I will discuss it with mechanic. Thanks
