Salam Everyone,
I want to go by the book in adjusting my Cultus' idle settings.
Problem:
1. When engine is turned on (ignition given) then the RPM lingers around 300,400 and after 8-10 seconds, slowly comes to the set line of 1100 rpm.
2. A few days ago after oil change (dont know if the chota touched it) but the RPM was on 1400 but the engine idles very good with ignition. So I know that the problem maybe with idle setting and no butterfly cutting or sort.
Question:
There are two scews on the carburetor. i.e. Idle Mixture and Idle Speed (ref 1).
I want to know the ideal positions (factory default) for these screws so I can see what is working and what is not.
Thanks.
Ref 1: https://www.pakwheels.com/forums/performance-modification-tune-up-preventive-maintenance/181721-cultus-engine-body-overhaul-rebuild-25
