Thank you for the reply. Yes, the vehicle does heat up once on the motorway because I mostly use the vehicle within the city.
On the highway, with the AC on and a high load, coolant usually overflows into the reservoir bottle and leaks out, so I top up the coolant.
According to the mechanic, there are no bubbles in the radiator, so there's no gasket leak, which I am really skeptical about. That's why I went for a compression test.
As far as I know, no gasket has been changed , so far i have used KIXX , Shell and this time i have used caltex 20w50 .
