I have a cultus 2011 model, there's an issue that it's leaking oil and white smoke keeps coming out whenever I accelerate, be it in the morning or afternoon; the white smoke is always there.
White smoke usually means water is being burnt along with air and fuel in the cylinders. Blue smoke means oil is being burnt. So if we go with the hypothesis that water is being burnt, then the next question is: Is the coolant level reducing? and do you see bubbles in the radiator when you open the radiator cap?
Where is the oil leaking from?
White smoke could be due to multiple reasons.
Is the radiator water reducing? Is there missing?
The radiator is not consuming less water nor is the oil level decreasing. However, a little bit of oil is leaking from the right side of the carI have also changed the car's head gasket. But still, there is a problem with white smoke.
It could be valve seals. Check the PCV as well.
