My cultus is hesitating alottttttt now...but this occurs suddenly and momentarily and keeps on going again and again... Its like even if i press the accelerator till floor, the rpm keeps on falling and seems like the engine power is totally cut...and within 2 seconds the car is back to normal and runs perfectly fine!!! In the morning/cold start, yes it gives a good amount of smelly white smoke and then all is ok and smokeless...showed it to Enercon Scanning Karachi and he said all sensors are fine as no Check light..he said efi cultus me cng ki electronic T/lambda masla hai isko manual wali laga dete hain hopefully you will good to go...but the problem stands unresolved!
Please give your valuable input..
Please note i have brand new plug wires and plugs...new air filter, tappets setting done...
