How much does kabli efi engine cost for cultus ??help plzz
Depends on the city u r in. Different areas, different prices.
About 3 montha back one pathan was selling for 75k with all wiring ecu everything in mithu khan rawalpindi... I was searching for cultus carby assembly which costed me 42k
From lhr or fslabd?
Its bloody expensive thou??wat about carby thn?how much does tat costs?
Around 60k japani engine..dont know the current rates Sigapore engines are 5 percent cheaper than japani...
Yes the kabariya here will start from 70 can be easily noegociated to 65 and with reference maybe 60 or 62....you need to be expert in bargaining.
Inwhich engine i swap in kia spectra? Helpp
Dec 24 - AoA. I have 2010 model cultus. Its engine has become very weak now. Can i change its engine with new one atomatic? If possible how much estimated cost will be? Thank...
I bought cultus 2008 efi 3 months back. The gasket burnt a couple of days ago, my mechenic told me to change its head, pistons and crankshaft and it'll run as new. Also help me out if you get any idea about the cost.
I did the same .Cost was 60 thousand.It worked for 10000 km ( 6 month0.I used that with great care.I only used this below 80km/hr speed.A lot of problems with water circut pipes ,i managed succefully.Now after starting A/C i have issues of water circut problem.It is now currently under investigations wheather Gas ket is leaky.These Alluminium engines( EFi) are not very good for resetting you told above especially for A/C use.Cost is also very high.Replacement with new one may be better but i hve no experience of that.Brother go to super experts before spending money.
