Dear Members,
i have cultus efi 07 and having some issue in its performance. please read below detail and guide me.
head-gasket had been replaced recently with head faced by hand (mechanic covered the 8m plan mirror with racmar and rub it on head until the head surface doesn't get plan & equal). Also the radiator was serviced at the same time. after the work done, i was still observing some bubbles in radiator but mechanic said that it isn't an issue & also advise to drive car on petrol without AC for at least 2 days and i did.
car was having issue of getting engine off when at low speed or neutral so i get it checked from suzuki 3S and they tuned it & also serviced the throttle body. after that car was very smooth on petrol but problem persists on CNG specially when i turned-on AC, rpm gets fluctuate & car gets off (only when car is at low speed or neutral).
original suzuki radiator cap was also replaced because the old desi one's rubber was cracked.
Today i do the radiator test. radiator is throwing water to reserving bottle but didn't sucking it back, secondly when i did start the car with radiator cap open, its generating too much bubbles. (may b car is getting off due to heat-up issue).
please help me out to dig out what the exactly issue is and whom one can get it resolved in better way in islamabad.
