Can it be used in cultus on same grip or need to do desi jugar ?
Grip is same. Cultus TPS grip will work.
Ok. And what about IAC valve ?
IAC valves are same too. Infact, i am using baleno one on my cultus right now
For how much tou have bought the TB and any difference compare to g10b stock.
I have just installed baleno IAC valve on my cultus TB bro. I have a spare baleno TB which I will install after engine work.
This Issue got resolved by changing Fuel filler cap.
@engnr.mubashirQuite easy. BTW how much it costed?
As mine is also giving crack sound during tight clisi8
I bought it from 3S dealership for 3360/-
bro did yu changed your alternator if so please tell me? i have 06 cultus i want to change the alternator in order to gain around 1000rms for sound system. i would want to know which alternator will be volton in cultus 2006 and it must be 100 amp or above.
Try hilux alternator someone recommended me same alternator why I was looking ro change.
how much does it costs? hilux model? do i have to change the wiring? will it be bolton? how much ampere?
It will be bolt on fit and will cost you 4500 if you don't want to exchange with your old minus 1000 for exchange. You will have to run atleast 12mm wire from alternator to battery for load balance.
got it. and how much ampere will be hilux alternator?
I think 100 plus it is.
Which model year Hilux's alternator is bolt on in Cultus bro?
One sugestion while changing alternator. Try to maintain original electrical clamp by only changing part installed on altetnator,if it is in different shape.
wym?
Just to eavoid cutting of electric wires
Last generation.
