Head gasket urgya due to excessive heat but Heat ki sui opar nahi gy. I am using cultus 2009 efi. Thora prishan hun as it's my first car. kal mena change karwa lia but for safe side fan direct krdia ha. Radiator ma thora masla ha wo ma In sha Allah next week tk new leluga. AC garmi ki waja sa full fan pa chalta ha to I am concerned if I am destroying my engine or what should be a good practice to follow here?
Change the sensor first? 13650-50g1 is the part number.
You're not destroying anything, engine overheating and RPM is a common issue in these cars and well documented here.
You need to get your cooling system checked and change the temperature sensor (part number: 13650-50g1).
This is a common issue, try looking for other posts. You'll hopefully find a solution.
Thanks. I am using this forum for the first time and got a really quick response.
Gasket leak exhaust manifold ki wahga sy bhi go jati hy cultus main. Search for it on PW
